Dragging Jama internal tab to new browser window
It would help to have the ability to drag an open Jama tab (the internal tabs that show items, sets, filter, etc) to another open Jama instance in another browser window. Most users have dual screens and want to move content right and left and not have multiple browser tabs and Jama tabs being opened and closed.
this would be very helpful0 -
As a workaround for this you could use your browser's "duplicate tab" feature to achieve similar results. For instance, lets say you have 3 internal Jama tabs open for Set 1, Set 2, and Set 3 and you want to move the Set 2 tab to a new browser window. If you click on the internal Jama tab containing Set 2, then right click on the browser tab that Jama is running in, and select "Duplicate" this will open a new browser tab with an instance of Jama running that contains the Set 2 internal tab open. You can then drag that browser tab to your 2nd screen.Alex
Fujifilm Sonosite0 -
Hi Alex,
thanks for the hint but duplicating the Browser tab is as creating a new separate instance of Jama.
I guess that Nick's proposal (and mine...), is to have the Set2 internal tab in a separate window and to still keep the connection with the original Jama-Explorer tree. So that if you select on another Set in the 1rst window explorer, it would update in the second window.0
