Export does not consider the filtering criteria
[Deleted User] Posts: 3
edited March 2020 in
I have selected a list of requirements under a parent FD to export, but the export function will always export all items to word or excel regardless the filter applied to the list view.
Below image shows that I have applied a filter to show only requirement type at the list. But export will include all other types including text and folder. How can I export only items show at the list view?
Celeste Hong
  • Alex Frain
    Alex Frain Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 29
    edited March 2020
    Hi Celeste,
    We are running v8.36,0 and noticed this as well.  You'll need to create a filter using Jama's Advanced Filter in order for exports to respect the filter results as opposed to the using basic Filter you referenced in your screenshot.
    On a side note, we have a test instance running v8.42.1 and exports do appear to work as expected with the basic filters in this newer release.
    Alex
    Fujifilm Sonosite
  • Vladimir Cech
    edited March 2020
    Hello Celeste, Alex,
    We are facing similar issue with 8.47 cloud version. Even when advance filter is created the Excel export contains much higher amount of items. In fact it exported items until Excel row limit was reached. I'm in touch with Jama support and they claim that our instance must be fully re-indexed.
    I'm little bit skeptical but I give it a chance.
    Vlada
    edited March 2020
    Hi Alex, Vlada,
    Thanks for responding. Advance Filter didn't work for me either.
    Vlada, does re-indexing work for you? Please share.
    Thanks.
    Celeste Hong
    Sent: 03-05-2020 00:57
    Subject: Export does not consider the filtering criteria
    Vlada
    Sent: 03-04-2020 11:42
    Hi Celeste,
    Alex
    FujiFilm SonoSite
    Sent: 03-03-2020 07:58
    Celeste Hong
  • Vladimir Cech
    edited March 2020
    Hello Celeste,
    Unfortunately re-index did not help. I continue with Jama team in investigation.
    I also informed Jama team about this post. I hope that they will go in touch with you as well.
    Vlada
    Vlada
    [Deleted User] Developer Support Engineer Posts: 2
    edited March 2020
    Hi Celeste,
    I'm the one looking into Vlada's filter issue. Could you message me a screenshot of the filter being used or file a support ticket?
    [Deleted User] Posts: 73
    edited March 2020
    Noticing this thread I also gave it a try in our instance (On-Prem) with the following result:
    - Jama 8.36.4: Standard Excel export does not consider the aditional criteria
    - Jama 8.42.1: Standard Excel export exports only the filtered items
    Advanced filtering and exporting via standard excel export seems to work fine in both versions.
    Assuming that Alex is onPrem as well (which I assume because of the version number), this confirms the observations.
    The Release Notes for 8.42.1 even mention this bug:
    SOS-DEF-633/SOS-BUG-802
    List View filter facet does not filter out results when exported.
    Regards
    Anna Henke
    Sent: 03-09-2020 18:16
    Hi Celeste,
    Justin Phang
    Celeste Hong
    edited March 2020
    Thanks Anna for the confirmation.
    PS: We are running on V8.31.1.
  • Vladimir Cech
    edited March 2020
    Hello All,
    With Jama support we identified the problem in our case - when test cases are part of the filter during the export to Excel each test step is recorded as 1 row. It means that 1 test case with 10 test steps is presented as 10 rows in Excel.
    Hope that this is fixed soon.
    Vlada
    Sent: 03-10-2020 07:28
    Celeste
    Sent: 03-10-2020 05:03
    Regards
    Anna Henke
    Hi Celeste,
    Justin Phang
    Celeste Hong
    Vlada
  • Vladimir Cech
    edited March 2020
    The problem that we face was labeled as expected behavior :-(
    Vlada
    edited March 2020
    Hi Vlada!
    I think your Excel line item results are being salted because of the Test Steps. Try going into the List View of your Advanced Filter > Config Cog > and then uncheck the "Steps" from showing up in the List View.
    Next, I would refresh the browser and then export to Excel
    When I tested this in my instance I went from having about 30 Excel line items to just the 8 Test Cases I was filtering for. Depending on what kinds of items you might have in this filter, you might still have more to drill down... But, let's start here and see what the numbers look like.
    In my test it went from this:
    To this:
    Which was on par with my filter results.
    Vlada, let us know if this helps!
  • Vladimir Cech
    edited March 2020
    Thank you Chloe,
    I appreciate that you stepped in to this problem and provided valuable information. Yes, when the Steps options is unchecked the export is working fine (one row for each item is exported).
    I still consider this as a defect in Jama (more precisely said misleading logic and hidden functionality because it took nearly 3 weeks to find how Jama is working in this case).
    When I see the list view it's possible to see only number of test steps but not step actions as it is in Excel export - see attached file. It means that more data are exported to the Excel than are visible in the list view and you are not possible to affect it (if the default Excel template is not changed or steps are unchecked). With unchecked Steps option also number of steps is not exported.
    The best and easiest solution is to update default Excel export to export only in data visible in the list view (no hidden export of not presented columns)
    What do you think? When Jama able to do update the template or perform a wider fix (e.g. a check box to explicitly allow export of test steps)?
    Thank you
    Vlada
    Sent: 03-11-2020 14:21
    Hi Vlada!
    Next, I would refresh the browser and then export to Excel.
    To this:
    Sent: 03-11-2020 01:58
    Vlada
    Sent: 03-11-2020 01:16
    Hello All,
    Vlada
    Vlada
    Celeste
    Regards
    Anna Henke
    Hi Celeste,
    Justin Phang
    Celeste Hong
    Vlada
