Global Find/Replace Feature
I'd be interested in solutions for this as well, we often clone projects as a starting point for new developments and it is very tedious to replace references to the product name for example0
Can we get an update to this request? Thank you~
Sherry Lucas
Operations Manager
Defined Contribution Solutions
Alight Solutions
Texas - Virtual
m 936.525.0766
Certified Great Place to Work®
------Original Message------
I'd be interested in solutions for this as well, we often clone projects as a starting point for new developments and it is very tedious to replace references to the product name for example0 -
We are interested in this functionality as well
------Original Message------Can we get an update to this request? Thank you~
Sherry Lucas
Operations Manager
Alight Solutions
Texas - Virtual
m 936.525.0766
0 -
We desperately need this functionality as we need to find and replace a lot of text in different requirements. This is a basic functionality and I am surprised that Jama lacks this functionality.
Regards,
Maryam Ahanchi
SiriusXM
0 -
Hi Maryam:
cc: @Maryam, @Sherry, @Karen
I would like to invite you to visit our new Ideation module in the Community! This is the new space where we will be soliciting and gathering product feedback. You can go here, and use the search functionality to see if your idea is already in there. If it is, then you can vote and comment in the card. If there isn't, please post a new idea card! See our new Product Idea process here.
Sent: 05-18-2020 08:08
Subject: Global Find/Replace FeatureWe desperately need this functionality as we need to find and replace a lot of text in different requirements. This is a basic functionality and I am surprised that Jama lacks this functionality.
Regards,
Maryam Ahanchi
SiriusXM
Maryam Ahanchi
SiriusXM
FL
Sent: 10-24-2019 14:38
We know there is a Find/Replace feature on an individual requirements page. Is there a procedure for making find/replace edits over an entire project?
Sherry Lucas
Alight Solutions
The Woodlands, TX
