Find and Replace
We are using Jama to build a requirements document that when completed will be 1000+ pages and it contains huge amount of text. I plan on duplicating this for another project in the future, and as of right now, I'll have to use one of the workarounds such as export/import into/from excel, or go in an touch each item that has the old system name to replace with the new system name.
I'd argue that find and replace is something that one would simple "expect" to be in a product like Jama, and shocked to find out that it doesn't exist. As the Jama advocate in our company, I was embarrassed to tell a co-worker that it doesn't exist when she asked. Until she asked, I had no idea that something so basic didn't exist, as I had assumed it was just there and would be there when I needed to use that feature.
This is a feature that I would very much like to have.0
+1 - we would love this feature.0
Yes this would be a good feature.
------Original Message------
+1 - we would love this feature.0 -
+10
