Find and Replace
[Deleted User] Posts: 8
edited August 2019 in
Looking around, it looks like the first request for Find and Replace was made sometime in 2015. I'd like to follow up with another request to offer users the ability to do a "find and replace" for text that are in text fields, rich text fields, and etc.
We are using Jama to build a requirements document that when completed will be 1000+ pages and it contains huge amount of text. I plan on duplicating this for another project in the future, and as of right now, I'll have to use one of the workarounds such as export/import into/from excel, or go in an touch each item that has the old system name to replace with the new system name.
I'd argue that find and replace is something that one would simple "expect" to be in a product like Jama, and shocked to find out that it doesn't exist. As the Jama advocate in our company, I was embarrassed to tell a co-worker that it doesn't exist when she asked. Until she asked, I had no idea that something so basic didn't exist, as I had assumed it was just there and would be there when I needed to use that feature.
    [Deleted User] Posts: 46
    edited August 2019
    This is a feature that I would very much like to have.
  • Rebecca Street
    Rebecca Street Member Posts: 7
    edited August 2019
    +1 - we would love this feature.
    [Deleted User] Posts: 29
    edited August 2019
    Yes this would be a good feature.
    ___________________________________________________________________________
    ------Original Message------
    [Deleted User] Posts: 49
    edited August 2019
    +1
