Product Idea
Cannot select field for "Test Case ID"
  • 1.  Cannot select field for "Test Case ID"
    Posted 07-26-2018 02:38
    One of the request from my users is the following:
    Cannot add "Test Case ID" to the select-able columns of a test run.
    I've checked the list of columns but there is no "Test Case ID"
    Is there a way to do this and add the "Test Case ID"?
    Marcel Bachus
    Innolux Technology Europe B.V
  • 2.  RE: Cannot select field for "Test Case ID"
    Posted 07-26-2018 11:51
    Marcel:
    If you have Jama 8X, you would be able to use Traceview which would allow you to view upstream the test cases attached to the test runs. We upgraded the Test Center, especially, to have assumed traceability - this upgrade in 8x answered a lot of customer our needs.
    Business Support Engineer
  • 3.  RE: Cannot select field for "Test Case ID"
    Posted 07-27-2018 08:34
    We have 3 small-ish improvements under consideration and making the Test Case ID more accessible is one of these.
    The options being considered are
    1. update the existing Test Case field to include the ID
    2. changing the current Test Case field to just be the ID
    3. adding another field specific to the Test Case ID
    I was leaning toward the second option as showing the Test Case name is just a duplicate of the Test Run name 99% of the time.
    Other small improvements were to move the description above the steps within the test execution dialog and add ability to include a rich text template for the actual results on the test run.
    Steve Gotsch
    Product Manager
  • 4.  RE: Cannot select field for "Test Case ID"
    Posted 07-28-2018 06:34
    I would vote for 1or 2, and prefer 2 (just ID). Test case names become meaningless on large projects.
    Steve Kay
  • 5.  RE: Cannot select field for "Test Case ID"
    Posted 07-29-2018 23:34
    for our Team, the Option 2 will help us a lot with our current work with test Management Feature.
    Lien Bäcker
  • 6.  RE: Cannot select field for "Test Case ID"
    Posted 07-30-2018 14:45
    Edited by mark 07-30-2018 14:47
    ​Option #3.
    mark gregori
