The full Test Cycle name should be shown
Kasper Hansen
Member Posts: 3
In the "Test Runs" area of a Test Plan, there is a drop down list of of all the Test Cycles. Our problem is that the length of the drop down is too short. This means that we can't see the full name of the test cycles in the drop down. We suggest that the field is expanded.
Kasper Hansen
GN Audio
Denmark
GN Audio
Denmark
The drop down on the test run panel can be expanded by dragging on the box when it is opened. Is the the drop down you are referencing?
0 -
Yes, this is the drop down I'm referencing. It would be more convenient if it by default was wider, as we all the time need to expand it manually.
Br,
Kasper
Sent: 6/15/2020 10:27:00 PM
Subject: RE: The full Test Cycle name should be shown
Kasper Hansen
GN Audio
Denmark0 -
Steve Kay Member, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 28Options
+1
Stephen Kay
Sr. Systems Test Architect, BSHS SQA
M 302.563.5539 O 302.631.2738 E Stephen.Kay@hologic.com
L 600 Technology Dr., Newark, DE 19702
Sent: 6/16/2020 1:15:00 AM
Subject: RE: The full Test Cycle name should be shownYes, this is the drop down I'm referencing. It would be more convenient if it by default was wider, as we all the time need to expand it manually.
Br,
Kasper
Steve Kay
Principal Systems Test Architect
Hologic - Breast Health0
