Compare view for items reused and synchronized
Grace Gandanegara
Member Posts: 3
Actually, when we reuse twice the same requirement in the same project from a library, when we go in the view sync items at the project level, then after selecting "compare items" with the library, we can see that JAMA displays only one sync item from that project regarding the library and not all the sync items.
That's true that, if we select one item, it will give the list of items that it is synchronized to. However, what we want is to have side by side in compare view at the higher level all the items that are synchronized, so that we can track them more easily.
It would be great if we can have the compare view for all items reused and synchronized.
Thanks.
Best regards,
Thanks.
Best regards,
