Many in my company have come to me noting their frustration with trouble removing test cases from a cycle. Even with the process explained there have been several occasions which it's simply not working and in general if it does work the method is very tedious with the need to go to the Test Cases tab and finding the tests to remove, add them to a group, then back to the Test Cases tab and edit the cycle then remove that group. Because of the flow to remove tests several members are apprehensive to even try the removal process because they are concerned they will corrupt the cycle. Due to this UX issue we now have many cycles with blocked cases causing clutter in the reports because the team is unable to or unwilling (due to a distrust in the functionality from the previous failed attempts) to figure out the removal process.
….Can we please get a simple Trash icon or remove option of some sort within the Test Runs screen to make this feature much simpler?
Noam Kowitt
