Default value for "User" field (e.g. current username)
This is an old topic but we still find very tedious to create items when these include a "User" field that is marked as mandatory (required) since users will have to independently select their username from the list for every item that is created.
Is there any known workaround or does Jama Software have any plans to add a capability to be able to configure a default value for a "User" type field (for example the current username)?
I too like to see this kind of default user as current user handy.
E.g. when tests are run by user it is usually the same person who has found the defect and should be stored as found by field. Of course this information is available in Created by field too but then you need to search two fields in case someone else is storing sometimes the defect.Anja
[Country]0
