Velocity template problems
  • 1.  Velocity template problems
    Posted 03-25-2020 08:54
    Hi
    In our test environment 8.31.1 we have problems when generating reports via velocity template. In the generated Word document it only says No Result, see attachment ExportToVelocityTemplate.png. Log file from contour in attachment VelocityReportError.txt
    But if we generate the report directly to word it is OK attachment ExportToWord.png.
    I have imported a database from production, I did that by backup/restore in MSSQL. I didn't use the Jama backup procedures.
    Raimo Berglund
    Nasdaq
    +46734496524
    Attachment(s)
    txt
    VelocityReportError.txt   11K 1 version
  • 2.  RE: Velocity template problems
    Posted 03-30-2020 07:28
    Edited by Chloe Elliott 03-30-2020 08:47
    Raimo:
    This will require comparing the Velocity report with the logs. For instance, which function was being called when the method fails at line 98? Is this a custom report or one of our Community reports? If you make a ticket with our Technical Support team, we could take a look with you and see if we can pinpoint the problem.
