Can we customize Test Run Status state values?
  • 1.  Can we customize Test Run Status state values?
    Posted 12-06-2018 16:21
    Hi-  I see in documentation that Test Run Status has these 5 States:
    1. Not run
    2. In progress
    3. Passed
    4. Failed
    5. Blocked
    Is it possible to add our own custom states in Jama Connect 8.31.1?
    Christopher Campbell
  • 2.  RE: Can we customize Test Run Status state values?
    Posted 12-10-2018 16:16
    Edited by Chloe Elliott 12-12-2018 11:34
    Christopher:
    Hello, I need to correct my answer from before. If you are talking about the tab showing the status of the test run while it is in progress, then this is not an item field which can be changed and configured in Jama.
    Thank you @Theresa for pointing this out to me!
  • 3.  RE: Can we customize Test Run Status state values?
    Posted 05-16-2019 12:42
    ​Can Test Run Status types be customized by project or all as administrative option?
    The note referenced as "correction" seemed to indicate that it was possible.
    Donna Houle
    Comcast
    Manchester NH
    603-695-1741
  • 4.  RE: Can we customize Test Run Status state values?
    Posted 05-20-2019 13:02
    Donna:
    The Test Run Status type, as exampled above within the Test Run, is not customizable. It's hard-coded into the Test Center UI. In some places and situations you could add custom pick-lists to the item-type but, it wont trigger Test Center functionality. It would just be for your information only.
  • 5.  RE: Can we customize Test Run Status state values?
    Posted 6 days ago
      |   view attached
    ​Hello Team ,
    We want add some additional field values to test case status. What want specifically mention why this has failed
    For example:
    1. SCRIPT_FAILURE
    2. ENVIRONMENT_FAILURE
    3. CODE_CHANGE_FAILURE
    4. FLACKY_ISSUE
    Also we want generate dashboard using filters/widgets.
    Could you please add this feature of customization of field values to test case status.
    This will be more helpful/informative.
    Regards,
    Abubakar.M.K
    Abubakar Karajagi
    EATON
    pune
    02066337608
  • 6.  RE: Can we customize Test Run Status state values?
    Posted 6 days ago
    Abubakar:
    You cannot add custom fields directly to the Test Case Status but, you can ask your Organizational Administrator to make a custom multi-select pick-list then add this custom pick-list to your Test Case item-type (or whichever item-type you are using as a Test Case).
    This list will not inform the "status" and will only be available in the Test Case item but, you can use this to inform your team members and stakeholders "the reason" this particular test case failed. You can then use this same custom picklist in our Advanced Filters to find the exact Test Cases you need, like so:
    These Advanced Filters can then be sent to the Review Center or used to inform a dashboard widget within Jama (see the "Filter Results" widget).
    Let me know if you have any questions!
