Edit and add custom fields on Test Cycle
  • 1.  Edit and add custom fields on Test Cycle
    Posted 06-07-2019 05:27
    in Jama versions after 8.10 there is no possibility to edit or add custom fields on Test Cycles. We have some custom fields that our users wished to change and we are not sure how to do it.
    We are running 8.25 and validating 8.36, in both versions this feature is unavailable.
    Ekaterina
  • 2.  RE: Edit and add custom fields on Test Cycle
    Posted 06-07-2019 11:45
    Ekaterina:
    How are you wanting to use these custom fields? Do you just need them there to inform or do you want them to interact with the Test Center process in someway? I ask because if you just need to inform, we might be able to figure something out - depending on what you need to do. But if you need these custom fields to actively trigger functionality within the Test Center, this will most likely not be possible.
    If you are able to tell me a little more about what functionality you are trying accomplish, I would love to brainstorm this with you.
  • 3.  RE: Edit and add custom fields on Test Cycle
    Posted 06-11-2019 02:49
    Hi Chloe,
    we already have several custom fields created in a test cycle, that just contain information about a test cycle, that we are using for filtering purposes and for generating Velocity reports. At the moment we cannot edit or delete those.
    Our Test Team had some ideas to add additional fields for similar purpose, i.e. they would not need to provide any additional functionality than just displaying the information in cycle view details page. And another idea was to add a template to a test cycle description field.
    Thanks a lot,
    Ekaterina Kessner
    MeVis Medical Solutions AG
  • 4.  RE: Edit and add custom fields on Test Cycle
    Posted 06-12-2019 10:28
    Ekaterina:
    Perfect, I would say that if you are thinking your users will want to also use these custom fields to filter and to inform Velocity reports (even if this is just a possibility for in the future) I would use the Custom field option.
    You could do a custom template but, this would be a RTE field and the information within would not be searchable. Therefore you couldn't use it to filter or add to a dashboard etc. Perhaps a combo of the two ideas might work for your team?
  • 5.  RE: Edit and add custom fields on Test Cycle
    Posted 06-13-2019 07:20
    Edited by Ekaterina Kessner 06-13-2019 07:20
      |   view attached
    Hi Chloe,
    the problem is, in our 8.25.1 and 8.36 instances there is no edit or delete buttons for test cycle fields, please see attached. So we do not have a possibility to edit, or delete existing custom fields or do add new ones.
    Please, consult
    Ekaterina Kessner
  • 6.  RE: Edit and add custom fields on Test Cycle
    Posted 06-14-2019 13:06
    Ekaterina:
    Thank you for your patience, this new information you have provided has caused me to do a little bit more discovery on the history of the Test Cycle item. I have my feelers out, and I will get back to you when I have more info to share. I just didn't want you to think I have forgotten about you.
    Regards,
  • 7.  RE: Edit and add custom fields on Test Cycle
    Posted 06-20-2019 06:24
    Hi Chloe,
    ok, thank you.
    BR,
    Ekaterina Kessner
  • 8.  RE: Edit and add custom fields on Test Cycle
    Posted 06-20-2019 13:30
    Ekaterina:
    The Test Cycle item-type fields were configurable in an older version of Jama. Sounds like this is when these custom fields were added to your Test Cycle item-type. This capability was taken out around mid 2018 and is no longer available for this item-type.
    So, if the focus needs to be specifically on the Test Cycle, then the best way would be the template idea in the description field. You could then have this whole field pulled up into your Velocity reports.
  • 9.  RE: Edit and add custom fields on Test Cycle
    Posted 06-24-2019 07:08
    Hi Chloe,
    would it be possible to transform this request (edit/add custom fields on a Test Cycle) into a feature request?
    Thank you in advance,
    Ekaterina Kessner
  • 10.  RE: Edit and add custom fields on Test Cycle
    Posted 06-24-2019 12:02
    Ekaterina:
    Yes, I looked at options and the best thing to do is to make a Product Idea here.
