Topic: Mirroring Related Items after Initial Reuse
1.  Mirroring Related Items after Initial Reuse
Posted 7 days ago
We have a use case where we want to reuse an item with sync initially, and then later on mirror the downstream related items from the original item.
At the initial reuse we select the sync option: "Do not synchronize relationships". Then, later on, we re-sync from the original item, this time selecting: "Include related items and mirror relationships". However, the related items do not actually get mirrored. After the second sync, I see that the reused item just copies the relationships from the original item. I would expect that the related items are instead mirrored and that the reused item is related to those mirrored items.
Christopher Carroll
Viasat
Carlsbad CA
