Can we customize Test Run Status state values?
  • 1.  Can we customize Test Run Status state values?
    Posted 12-06-2018 16:21
    Hi-  I see in documentation that Test Run Status has these 5 States:
    1. Not run
    2. In progress
    3. Passed
    4. Failed
    5. Blocked
    Is it possible to add our own custom states in Jama Connect 8.31.1?
    Christopher Campbell
  • 2.  RE: Can we customize Test Run Status state values?
    Posted 12-10-2018 16:16
    Edited by Chloe Elliott 12-12-2018 11:34
    Christopher:
    Hello, I need to correct my answer from before. If you are talking about the tab showing the status of the test run while it is in progress, then this is not an item field which can be changed and configured in Jama.
    Thank you @Theresa for pointing this out to me!
