Product Idea
Visualizing Test Case fields in the 'Test Cases' view
  • 1.  Visualizing Test Case fields in the 'Test Cases' view
    Posted 19 days ago
    We use Jama primarily as a Test Management tool for manual testing and therefore we would like to see improvements in this area.
    Proposed enhancement: Currently, it is not possible to view Test Case fields in the 'Test Cases' view or search/filter/sort by a specific field. This could greatly help ensure that Test Cases have been properly allocated to Test Groups and perform.
    Note: In general, the options for managing/visualizing Tests Cases in this window are very limited.
    Raul Gomez
  • 2.  RE: Visualizing Test Case fields in the 'Test Cases' view
    Posted 5 days ago
    We have the same issue. It's also impractical to check that a Test Case is allocated to a Test Plan.
    You can create a filter: "Test Case Status = Not Scheduled" but this does not make the difference between Test Case in no Test Plan (=work is planed) or in no Test Cycle (= work is started).
    You can create a filter: "Has test Run in Test Plan X" but that would (I could not make this filter work, BUG?) work only after allocation to a Test Cycle (what creates a Test Run item).
    To filter Test Case not allocated in a Test Plan, one could try to do "(Test Case Status = Not Scheduled) AND None (Has test Run in Test Plan = all tests)". I was not able to check this: "Has test Run in Test Plan X" looks like not working and I'm not sure a multi-selection of Test Plans is working (I can select, but can't be sure that the "Select Item (no s)" does the job).
    (0) Please make customizable fields columns in Test Case view.
    (1)  Fix the " in Test Plan" filter,
    (2) a Filter "In Test Case" would be more than welcome.
    (3) It would be nice also if the Test Run widget would show "0" when a Test Case is allocated in a Test Plan and no number or "-" when not allocated.
    Christian Binard
    ON semiconductor
    Belgium
  • 3.  RE: Visualizing Test Case fields in the 'Test Cases' view
    Posted 5 days ago
    Correction:
    (1) Fix the "Test Run in Test Plan" filter,
    (2) a Filter "Test Case in Test Plan" would be more than welcome
    I've mirrored this request in Jama Ideation, please reply in that page.
    Raul, thanks for voting for the idea in Ideation page
    https://community.jamasoftware.com/ideation-home/viewidea?IdeationKey=253ba504-eeb9-4348-ba68-1b9156bb3605
    Christian Binard
    ON semiconductor
    Belgium
