  • 1.  Fields in Test Runs
    Posted 01-18-2022 14:13
    I have added a Text Field to the list of Fields in my Test Case item specification.
    This filed does not appear in the Test Runs that are created from my Test Cases and I would like it to appear.
    Is there a way to this Field to appear in Test Runs?
    Ian Webb
    Enphase Energy, Inc.
  • 2.  RE: Fields in Test Runs
    Posted 01-19-2022 19:46
    Hi Ian,
    Is the text field that was added a custom text field, or was it a standard one (such as ID, Name, Item Type, Description, etc)?
    If it was a standard text field, it could be hidden (Configure test run view). If it's a custom text field, I'd recommend checking it against the supported custom text field types listed in Configure custom fields to appear during test execution as non-supported custom text field types won't appear in the test run execution panel.
    I hope that helps! Please let us know if you have any other questions or need additional support.
    Carly Rossi // she/her
    Portland, OR
  • 3.  RE: Fields in Test Runs
    Posted 01-20-2022 13:59
    Hi Ian,
    in my understanding only
    • name
    • description
    • steps
    get copied to the generated test run.
    Best regards,
