Product Idea
Can I define a field that is filled in during a test run?
  • 1.  Can I define a field that is filled in during a test run?
    Posted 10-22-2015 15:02
    When we execute a test run, the tester can select Pass/Fail and enter a Result for each step, and they can also enter whatever they want in "Actual Results", but there isn't a way to define a fixed field that the user can fill in?
    It seems like everyone has the need to record "Which Version of my Widget am I Testing", it seems odd that there isn't a way to define fields that testers fill in during testing ...
  • 2.  Re: Can I define a field that is filled in during a test run?
    Posted 10-22-2015 17:54
    Chris, great question. There isn't a way to change what is visible during Test Run Execution. (Because if you add a custom field to a Test Run, it's only visible while editing the Test Run, or viewing it as a single item.) However, I'm really not sure about the design philosophy for limiting the configuration of the Test Run type or the execution window itself.
    Others have pointed out the need to have">https://getsatisfaction.com/jama/topics/is-it-possible-to-have-custom-test-case-fields-show-in-test-runs"> custom Test Case fields transfer to Test Runs, but I don't think I've heard of this exact need before. I'm going to change this question to an Idea to reflect it as being something you'd like to see in the product.
  • 3.  Re: Can I define a field that is filled in during a test run?
    Posted 11-02-2015 15:49
    I need to capture a test environment per a test case, not one for all test cases.  So, it would be great if Jama can handle this.
  • 4.  Re: Can I define a field that is filled in during a test run?
    Posted 11-02-2015 20:39
    That's understandable. Thanks for providing context, kyoko.
  • 5.  RE: Re: Can I define a field that is filled in during a test run?
    Posted 29 days ago
    I would suggest that folks who want to see improvements in Test Run capability go here arnd vote: https://community.jamasoftware.com/ideation-home/viewidea?IdeationKey=a04c8083-57fc-4347-80d1-5cd1ea4b4c3f#ItemCommentPanel
    Andrew MacCormack
    LumiraDX
