Recursion and Velocity
  • 1.  Recursion and Velocity
    Posted 06-10-2019 05:37
    Can someone provide a example of how you can achieve recursion within a velocity report please?
    Basically given a document I would like to go back the relationship (upstream) tree until the top if reached, i.e. the document has no further upstream relationships?
    Thanks.
    Andy
  • 2.  RE: Recursion and Velocity
    Posted 06-11-2019 11:03
    Andy:
    Hello, nice to hear from you today!
    Have you tried using a macro to do it. You can pass your item and whether you are going upstream or downstream.
  • 3.  RE: Recursion and Velocity
    Posted 06-12-2019 00:04
      |   view attached
    Hello Chloe,
    Thanks for your reply.  Well, I did look at Macros, unfortunately I think I have exceeded my programming skill level as I could not get them to work.
    Basically I can have a hierarchy of requirements (I've attached a sample)
    So I would be starting with a leaf requirement (R6) and I would need the macro to return R1, R2 as these are essentially the top level parents of R6
    If you could provide an example of how this could be achieved I would be very grateful.
    Andy
  • 4.  RE: Recursion and Velocity
    Posted 06-12-2019 08:50
    Hi Andy,
    you could do that also in a loop. Limits the the "recursion depth", but I would see that as a benefit.
    regards
    Harald
    Harald Hotz-Behofsits
    Frequentis AG
  • 5.  RE: Recursion and Velocity
    Posted 06-13-2019 08:40
    Hi Andy -
    You could use a macro if you are going to be doing this quite a bit, but often, I just do a loop and pick a high number (like 10) and have it stop at 10 levels, unless there is no relationship before then. I know it's not elegant, but it works.
    Shawnna Williams
