Topic Thread
Reporting Downstream Rqmts using WORD Templates
  • 1.  Reporting Downstream Rqmts using WORD Templates
    Posted 01-12-2018 14:02
    All,
    Is anyone using  Mail-Merge WORD templates to generate traceability reports?  I have been able to generate an upstream report, but am not having much luck with the downstream requirements.
    Upstream Works fine:
    «TemplateStart:Tier3_REQ»
    «documentKey»:«name» -«description»
    «TableStart:UPSTREAMRELATIONSHIPS»
    «documentKey»: «name» -  «description»
    «TableEnd:UPSTREAMRELATIONSHIPS»
    «TemplateEnd:Tier3_REQ»
    No "DOWNSTREAMRELATIONSHIPS" in default template and when I use "RELATIONSHIPS" there are no downstream requirements  listed even when the downstreamrelationship count is >0
    «TemplateStart:Tier2_REQ»
    #Downstream Requirements: «downstreamRelationshipCount»
    «TableStart:RELATIONSHIPS»
    «documentKey»:  «name»  - «relationsipType»  Status: «traceStatus»
    «description»
    «TableEnd:RELATIONSHIPS»
    «TemplateEnd:Tier2_REQ»
    Larry Gerber
    Viasat
    240-686-4464
  • 2.  RE: Reporting Downstream Rqmts using WORD Templates
    Posted 01-12-2018 17:05
    All,
    It appears that I was loosing the mail merge info in my cut and paste  operations (moving from default template into my new template.  I was able to get the downstream requirements from the relationships table once I started with a fresh template and deleted all the other constructs... is there a specific WORD configuration field that needs to be set to prevent the loos of the mail merge info ?  Thanks!
    «documentKey» :  «name»    Type( «relationshipType» )
    Description:  «description»
    Larry Gerber
    Viasat
    240-686-4464
  • 3.  RE: Reporting Downstream Rqmts using WORD Templates
    Posted 01-16-2018 18:14
    Hi Larry,
    Perhaps try the macro on this page: Word Mailmerge Tips & Tricks | Windows Secrets Lounge under "Convert Text Representations of Fields to Working Fields" to try converting the field codes you pasted into working field codes.
    Justin Phang
    Developer Support Engineer
  • 4.  RE: Reporting Downstream Rqmts using WORD Templates
    Posted 01-17-2018 08:49
    Justin,
    Thanks, the information in the tips and tricks is very helpful!
                   Larry
