Product Idea
Velocity. Get Item type views.
  • 1.  Velocity. Get Item type views.
    Posted 06-25-2021 03:47
    I was wondering if it is possible to retrieve which fields are visible by default in different views using velocity.
    The goal is to create report to have an overview of views settings for each item type.
    Thank you.
    Kind regards,
    Roman
    Roman Sickaruk
    ON Semiconductor
    roman.sickaruk@onsemi.com
  • 2.  RE: Velocity. Get Item type views.
    Posted 06-25-2021 15:49
    Hi Roman,
    Thanks for reaching out! Velocity doesn't know what your UI looks like. It only knows what information you send it.
    Are you trying to determine what fields are showing by default in the Project List/Reading views?
  • 3.  RE: Velocity. Get Item type views.
    Posted 06-30-2021 02:09
    Hello Decoteau,
    Thank you for fast response.
    This is exactly what I am looking for (also with Review List/Single Item views). I try to create some kind of report for a team to be able to discuss/adjust these fields visibilities. Nowadays it is only visible per item type. It is not really bounded to Velocity. If there is any other way to export these fields visibilities for all item types, that would work too.
    I also agree with moving of this thread.
    Thank you again.
    Kind regards,
    Roman
    Roman Sickaruk
    ON Semiconductor
