No Set API Credential Option
  • 1.  No Set API Credential Option
    Posted 11 days ago
    I was approached by a developer interested in using the API Tokens but there is no option available within my instance to generate the API Credential Token.
    I have REST enabled and I use it daily via basic authentication in one my integrations, but i'm finding it strange I dont have the option for users to generate their own authentication token.
    Is this because im on-prem using the LDAP Authentication?
    Luigi Salce
    Bose Corporation
  • 2.  RE: No Set API Credential Option
    Posted 11 days ago
    Luigi:
    Yes, the LDAP and Self-Hosted do affect using the API Credential token, this is for Cloud only. Depending on how your LDAP is set up it wouldn't hurt to try this solution as outlined in this article Using REST API in a Self-Hosted SAML Environment. This was originally tested for SAML but, I was advised that it wouldn't hurt to try it for your case. Try it and let me know if this was a viable solution for you.
