@Andrew Collins, Im happy to report that we released this functionality in our 8.62.X release. We also added some more database configuration options in a following release 8.62.3. I would recommend upgrading to this one, if you have a Self Hosted environment.
If you are
on-prem, Here is a link to
8.62 Standard Release notes. See under "Introducing multi-mode authentication". You will want to pay special attention to the "notes for on-premises administrators", as there is a requirement to install two new database schemas for this release upgrade.
There are added options for these databases in the
8.62.3 release, so there will be more considerations in those Admin notes for your IT org to consider.
Cloud customers, you also received this capability back in March 2021 in the
8.61 Cloud release. You don't need to upgrade anything or add any database schemas, just contact our Support team to help you enable it in your root.
Sent: 01-03-2022 09:22
Subject: Is there a way for Jama to bypass our SSO/SAML setup? Jama needs to allow mixed authentication
I'd also like to upvote this idea. Presumably without it, you can't have external reviewers (a major downside).
Andrew Collins
Meteorcomm LLC
Renton WA
2538722521
Sent: 03-03-2016 14:44
We have SSO setup with Jama which is great because it allows our internal users to bypass having to log in every time. We also have consultants that are outside however. With some other applications we have on the same SSO we are able to give the consultants a link that bypasses the SSO so they can log in using an id that is not in our network. Does Jama allow for something similar? Our consultants don't have internal accounts and we don't want to have to give them internal accounts just to access Jama.
