We're using jama hosted solution and I've had a reported usability issue from my team when they are editing test cases
from the review centre. If you click on rich text formatted test steps to edit (even if its just text) you'll get
- all the html tags associated with the text which is very annoying and difficult to modifiy the steps in particular when you have images or any formatting in the field
- test step edit window part is not enlargeable so it is difficult to edit the test step itself in it's entirety.
This seems to be a result of the rich text bar not being available when you're editing the test steps in review centre.
See screenshot of a test case being edited in review centre below
Is there any nice work around where you can see comments and address the review comments for test steps as well as edit in rich text easily so you can add images etc or has this been fixed somewhere?
It would be VERY helpful if this bug were fixed quickly.
Jeffrey
