Velocity - Extracting URLs
  • 1.  Velocity - Extracting URLs
    Posted 03-01-2020 18:33
    I'm trying to include URL links of all documents in $documentList in my Velocity report to be displayed as hyperlinks/strings in the word report.
    I tried using the following assuming the link to be displayed as a paragraph content, but it didn't work.
    #foreach($vDoc in $documentList)
    <p>$vDoc.document.documentUrl</p>
    #end
    I also tried using documentUrlDao like below:
    #set ($test = $applicationContext.getBean("documentUrlDao"))
    <p>$test.getDocumentURLs($vDoc.document.id)</p>
    #end
    how to get the url of documents?
    Kind Regards,
    Ahmed
    Ahmed Ali
  • 2.  RE: Velocity - Extracting URLs
    Posted 03-24-2020 18:46
    Could you please help me on this issue.
    Regards,
    Ahmed Ali
    Nanosonics
  • 3.  RE: Velocity - Extracting URLs
    Posted 03-25-2020 15:35
    I'm still struggling to find a solution for this issue.
    Ahmed Ali
    Nanosonics
  • 4.  RE: Velocity - Extracting URLs
    Posted 03-26-2020 03:13
    why don't you build the URL on your own? Look at the URL for a given Item in the Single Item View.
    The variable parts are :
    • base URL -> use $project.getOrganization().getBaseUrl()
    • item ID ->  use $vDoc.document.id
    • project ID -> use $project.id
    I hope it helps ...
  • 5.  RE: Velocity - Extracting URLs
    Posted 03-26-2020 06:43
    Thanks Alessandro, very helpful.
    Yes, you would have to build it manually. There's a built in variable called $baseUrl you can use and append the document id and project id to that (you will have to use the url for a document from your system as a model). You can use the .concat() for adding to the string.
    Ahmed, sorry for the delay in getting back to you! thanks for reaching back out.
