1.  Text Box Field
Posted 11 days ago
​​I added a custom field using text box but it is not appearing on the item types I added it to.  When I use text field it shows up, but I need more characters than the text field allows, so that's why I am trying text box instead.  Anyone else have or had this problem?
Beth Williams
AEM
Kennewick WA
5093766258
2.  RE: Text Box Field
Posted 11 days ago
Hi Beth,
I'm curious what item types you are trying to add the custom text box too. Also, can you add a screenshot of the custom text box configuration?
Thank you.
Dana Medhaug
Technical Support Engineer
3.  RE: Text Box Field
Posted 5 days ago
​Sorry I posted a new message before I saw your reply.  I am trying to add it to User Story.
Beth Williams
AEM
Kennewick WA
5093766258
4.  RE: Text Box Field
Posted 5 days ago
Oops, I meant to say that I am trying to add it to all Requirement types.
Beth Williams
AEM
Kennewick WA
5093766258
5.  RE: Text Box Field
Posted 5 days ago
Edited by Dana Medhaug 4 days ago
Hello Beth,
Once you have configured the custom text box field you need to configure the views in which it will be shown in. I attached some screenshots for some visual assistance. Basically, just select the Admin tab and go to  Item Types > User Story > Config View. Once you get there select the views from the drop-down menu and add the custom field from the Hidden Columns to the Visible Columns side.
Dana Medhaug
6.  RE: Text Box Field
Posted 4 days ago
Awesome.  Thanks.
Beth Williams
AEM
Kennewick WA
5093766258
