Product Idea
Find when Suspect was set to "True"
  • 1.  Find when Suspect was set to "True"
    Posted 10-04-2018 11:47
    It would be a nice feature to be able to see when a suspect link was created between items. Maybe users could inspect the Version history and see notes in there for exactly what change triggered it.
    The problem is that there could be many changes that occurred in an item but finding the exact change that caused the suspect link to trigger could be buried and difficult to pinpoint.
    Nick
    Nick Hainline
    NV
  • 2.  RE: Find when Suspect was set to "True"
    Posted 10-11-2018 04:12
    We would be interested in such feature too.
    Ekaterina
  • 3.  RE: Find when Suspect was set to "True"
    Posted 10-12-2018 05:59
    rene
  • 4.  RE: Find when Suspect was set to "True"
    Posted 11-20-2018 00:40
    we also have the interest on this feature
    Lien Bäcker
  • 5.  RE: Find when Suspect was set to "True"
    Posted 12-04-2019 10:29
    +1
    I agree with Nick's assessment and would add that it's difficult to know how to update the downstream item without knowing the exact change that occurred in the upstream item. As currently implemented the "Suspect" flag tells us that something has changed but doesn't give enough information so that we know how to take action regarding the change.
    I have investigated ways to work around this issue, and here's the only solution I've found.
    1. Search the project Activity Stream for "suspect" and the item of interest.
    2. Identify the relevant event and note the date.
    3. Search the version history of the upstream item for versions around the date in the "suspect flag changed" event.
    4. Repeat for every suspect flag
    I'm guessing a Velocity report could gather this information using the EventLogDao and EventEntry but I haven't had time to finish implementing it.
    Theresa
    Fujifilm SonoSite
    WA United States
  • 6.  RE: Find when Suspect was set to "True"
    Posted 12-04-2019 23:38
    +1
    we are also interested.
  • 7.  RE: Find when Suspect was set to "True"
    Posted 12-05-2019 09:37
    Adding this use case from a Support thread:
    Our use case is that our tester have testscripts/testcases linked to system requirements.
    If somebody changes the system requirement, the tester must check if his script is still valid, so he/she must know what change of the upstream item caused the suspect.
    Right now the only thing I see is that a relationship IS suspect, not when. So it is possible that it was set 1 day ago or half a year ago.​
    Sebastian
    Requirements Engineer
    Sick AG
  • 8.  RE: Find when Suspect was set to "True"
    Posted 12-05-2019 09:38
    linking the full support thread:
    https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?MessageKey=efef698b-5c76-4b62-ba3d-26379fdaaa1c&CommunityKey=c9d20d4c-5bb6-4f19-92eb-e7cee0942d51&tab=digestviewer#bmefef698b-5c76-4b62-ba3d-26379fdaaa1c
