Project Admins cannot see inactive users
  • 1.  Project Admins cannot see inactive users
    Posted 12 days ago
    Our Project Admins report that the "View Inactive Users" option does not work.
    When they select it, they are not presented with inactive users in the listing of users --- only active ones. The functionality worked before, however, in the last year or two...it hasn't.
    Project Admins cannot see inactive users even when View Inactive Users option is selected
    Vanessa H
    State of Calfornia
    CA
  • 2.  RE: Project Admins cannot see inactive users
    Posted 9 days ago
    Hi Vanessa,
    a quick workaround could be a BIRT report (direct access to database without permissions) and then assigning the desired visibility to the report (user group of desired project administrators).
    OK, it is only to "read" ... better than nothing.
    Best regards,
  • 3.  RE: Project Admins cannot see inactive users
    Posted 8 days ago
    Hi All,
    Thanks for reaching out about this (and special thanks to Alessandro for this workaround.)
    I have been running some tests and checked with Product about this behavior and can now confirm the following:
    • If a de-activated user had Inherited Permissions at a higher-level, they will not show as Inactive at a Project level.
    • However, if the de-activated user did not have higher-level/Inherited permissions and were added to the Project directly, they will show up in that "Inactive" view.
    • Example of my test as a Project Admin viewing an Inactive User that had Project Level (not Inherited) Permissions:
