Create roundtrip template
Simone Bouwmans
Member Posts: 3
I would like to create an excel roundtrip template. I have a workaround, but I don't like it that much. It uses columns that are available for download and normally are added in the hidden columns:
Thanks, Simone
Simone Bouwmans
Thermo Fischer Scientific
- Indent and Children don't seem to be necessary
- API ID (rename to API-ID)
- Current version (rename to Version #)
- Header
Thanks, Simone
Simone Bouwmans
What are the reasons why you wouldn't just use the standard Excel for Roundtrip report? In particular, why would you care what information is stored in the hidden columns?
Sent: 02-02-2023 05:45
Subject: Create roundtrip template
I would like to create an excel roundtrip template. I have a workaround, but I don't like it that much. It uses columns that are available for download and normally are added in the hidden columns:- Indent and Children don't seem to be necessary
- Header
Thanks, Simone
Simone Bouwmans
I created an export with some additional explanation and functionalities:
- For our SRA there are some columns which have dropdown list. In our excel-way-of-working these lists are dependent (if you select something in column A, a corresponding list will show up in column B.)
- One of the calculation fields we have in excel is currently not possible in Jama
Simone Bouwmans
Sent: 02-02-2023 21:32
- Header
Thanks, Simone
Simone Bouwmans
