How to display DOWNSTREAM relationships using MailMerge Parent/Child function in Word Templates
Hello all, I seem to be having difficulty generating a working table in a Word Export Template that utilizes MailMerge code to display the downstream relationships of a defined item type.
We have previously used a couple different MailMerge techniques to display desired fields for exported Jama items. The first is the "Parent/Child" function, which was applied to our User Needs as shown below:
Another table technique used the "TemplateStart/End:[item type]" function, which was applied to our Design Input Requirements:
I want to be able to generate a Jama Export Template for a different item type that uses the "Parent/Child" MailMerge function as shown in the User Needs template to list several of the items' fields in a table, and I want an additional column in that same table to search and display all of the downstream relationships for each item. I don't want to use the "TemplateStart/End:[item type]" function that is used in the DIR template, because when the report is run and the items populate the table, the header row repeats itself for every single item instead of just showing up once at the top of each new page.
Is there a way to do this? Any and all help is appreciated.
Thank you in advance!!
------------------------------Grace Grishaber
Terumo Heart, Inc.
Ann Arbor MI
I think the downstream tag might be "RELATIONSHIPS" not "CHILDREN"
This works for me. However I've contained it in a single cell in the table.
«TableStart:RELATIONSHIPS»
«documentKey» - «eval_status»
«name» «evaluation_types»
«actual_results»
«TableEnd:RELATIONSHIPS»
David Sellnow
LGC - Biosearch Technologies
Sent: 08-01-2023 14:31
Subject: How to display DOWNSTREAM relationships using MailMerge Parent/Child function in Word TemplatesHello all, I seem to be having difficulty generating a working table in a Word Export Template that utilizes MailMerge code to display the downstream relationships of a defined item type.
Grace Grishaber
Terumo Heart, Inc.
Ann Arbor MI
David Sellnow
Alexandria Minnesota0 -
Here's what I use (and was generated a long time ago so don't ask me why ??):
Note that the dotted underline is hidden text.
Andy
Thanks and best regards
Andy
This message and any attachments contain information from MeteorComm which may be confidential and/or privileged. If you are not the intended recipient, be aware that any disclosure, copying, distribution or use of the contents of this message is strictly prohibited by law. If you receive this message in error, please contact the sender immediately and delete the message and any attachments
Sent: 8/2/2023 9:14:00 AM
Subject: RE: How to display DOWNSTREAM relationships using MailMerge Parent/Child function in Word TemplatesI think the downstream tag might be "RELATIONSHIPS" not "CHILDREN"
«actual_results»
David Sellnow
Grace Grishaber
Terumo Heart, Inc.
Ann Arbor MI
------------------------------Andrew Collins
Renton Washington0
