Export of Categories does not work
Verena Neumaier
Verena Neumaier Member, Functional Safety Kit (FSK) Posts: 23
I would like to export Items from Jama (with customized Office Template) which are assigned to different categories. Regarding this I want to export these Items with their categorie.
I used the field «categoryPaths» as it is described in the Reference Guide but it does not work?!
Is there another solution?
Verena Neumaier
Verena Neumaier
Aktormed GmbH
  • Iwan Kutter
    Iwan Kutter Member Posts: 25
    edited January 23
    unfortunately this does not work and it is a known defect: Export of Categories does not work | Support (jamasoftware.com).
    As an alternative, you can use a velocity report to export the categories: Category Name in Velocity Report instead of Path? | Support (jamasoftware.com)
    Here are some tips for creating a velocity report:  Quick Start: HTML Templates for Velocity PDF Reports (jamasoftware.com).
    Best regards, Iwan
    Iwan Kutter
    Requirement Engineer
    Bernina International
    Sent: 01-22-2024 05:16
    Subject: Export of Categories does not work
    Verena Neumaier
    Verena Neumaier
    Aktormed GmbH
    Iwan Kutter
    Alessandro Valli Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 785
    edited January 23
    BTW, is Jama Software planning to fix the defect???
    Sent: 01-22-2024 23:13
    Best regards, Iwan
    Iwan Kutter
    Verena Neumaier
    Verena Neumaier
    Aktormed GmbH
  • Alexander Masis
    Alexander Masis Member, Data Exchange Posts: 3
    we have the same need to add Categories to Word report…
  • Verena Neumaier
    Is Jama Software planning to fix the defect?
    There is no information in the actual release notes for version 9.17.0 Self-hosted?
