  • 1.  Add Custom Picklist to Testplan
    Posted 11-27-2023 02:01
    Hi, I wonder if there is a possibility to add a Custom Picklist to a Test plan. Not sure if Test Plan is treated as an item type and how to "tailor" them.
    Patrik Swahn
    Volvo Autonomous Solutions
  • 2.  RE: Add Custom Picklist to Testplan
    Posted 11-27-2023 21:20
    Yes, you can add custom fields (such as a custom Pick List field) to a Test Plan.
    If you go to the ADMIN -> Organization -> Item_types page, you will see that "Test Plan" is an Item type on which you can perform an "Add field" operation.
    Geoffrey Clemm
  • 3.  RE: Add Custom Picklist to Testplan
    Posted 11-28-2023 02:04
    Thanks, that worked perfect.
    Patrik Swahn
  • 4.  RE: Add Custom Picklist to Testplan
    Posted 10 days ago
    If we add the field to a item type. Does it effects to the particular project or all the projects existing in JAMA tool?
    santosh kaparthi
  • 5.  RE: Add Custom Picklist to Testplan
    Posted 10 days ago
    Item types in Jama are global to all projects in the Jama instance, so if you add a field to an item type, it appears in all projects that use that item type.
    Geoffrey Clemm
