  • 1.  API ID Skipping Values
    Posted 11-30-2023 09:03
    Hi, has anyone experienced a glitch when creating an item in JAMA pertaining to the API ID generation?  Specifically, the ID is skipping more than an 100 IDs.  For example, I'm adding the 70th requirement of a specification and expect to generate an equivalent API ID of XXXX-70 (I've successfully entered 69 requirements previously), but instead I get XXXX-232.  When I attempt to search for XXXX-70 in the database (or any number between 69-233), no data shows up.  Is there a way to bridge the gap or fix this?
    Yvonne Stephens
    Systems Engineer III
    Redwire Space
