  • 1.  Baseline Source data using Velocity
    Posted 10-24-2023 09:16
    I'm creating a velocity report that exports baseline information. I'm am wondering if there is any way to get data about the baseline sources (name and key). This data is readily available through the Rest API but I'm struggling to find any information when using velocity.
    Is there any way to retrieve baseline source data when generating a report using velocity?
    Adriaan Arnason
    Process Engineer
    Össur
  • 2.  RE: Baseline Source data using Velocity
    Posted 10-24-2023 23:26
    Hi Adriaan!
    You can read the refId and scopeId properties from the baseline object. These refer to the baseline source.
    Hope this helps.
    Regards,
    Peter Lampacher
    MED-EL
    Innsbruck
  • 3.  RE: Baseline Source data using Velocity
    Posted 10-25-2023 01:38
    Hi Peter,
    Unless i'm mistaken, those properties refer to origin of the baseline, not the baseline source.
    What I'm looking for is the baseline source information as presented in the baseline tab.
    If you know any way to get this information by using the refId and scopeId that would be greatly appreciated.
    Adriaan Arnason
    Process Engineer
    Össur
