By API ID, do you mean the document key? We weren't able to reproduce the behaviour you've described, so I want to be sure to confirm what you're looking for in order to give you another way to find the desired parameter accurately.
Carly Rossi // she/her
Portland, OR
Sent: 03-28-2023 09:12
Subject: browser url not updated when clicking on test case from the test plan (test cases view)
That's right. Only problem is the URL is not updated in the new tab.
Eric Roller
Illumina
CA
Sent: 03-27-2023 16:53
Hi Eric,
Just to confirm, you're not seeing any errors or delays here, just that the URL showing in the browser doesn't update in the new tab that populates when clicking on test case?
Portland, OR
Sent: 03-20-2023 10:34
A new jama UI tab opens for test case I clicked, but the browser url is not updated. Once in the jama UI test case tab I can click on the link under Project ID to show the correct broswer url for the test case even though it doesn't change anything in the browser view.
Maybe this isn't a bug, but it is very unintuitive. If I click on a test run from the test plan (test runs view) the test run opens in a new jama UI tab and the browser url is properly updated for the selected test run.
Eric Roller
Illumina
CA
