When on the Sync Items pane, the categories applied to items do not appear under the Categories column - this seems to be a bug. I would like to be able to see what categories are applied to each item in the Sync Items pane view.
- Expected: The categories applied to each item are visible under the Categories column on the Sync Items pane
- Actual: The categories applied to each item are not visible under the Categories column on the Sync Items pane. See Figure below
Trevor Wou
ON
