Hi Molly,
Thank you for trying the recommended workaround; since it hasn't worked when you've tried it, I'd recommend reaching out to our Support team to dig in deeper with you here.
To do so, please open a ticket here, and reference this thread in the ticket description (as well as the version and type of Jama Connect you're using, along with any other pertinent info) on it. In the meantime, I'll be closing this thread due to its age.
Carly Rossi // she/her/hers
Portland, OR
Sent: 05-15-2023 09:03
Subject: Changes in Diagram Editor are not being saved
I came across this exact issue while trying to edit a diagram in Jama. I tried the suggested workaround of aligning left and re-centering, but that did not work. Please address this bug -- it makes the diagram tool basically unusable. It appears that it was identified 5 years ago and still hasn't been resolved.
Molly Flanagan
Sent: 11-30-2020 14:33
Hi team
It looks like the behavior you are reporting is a bug related to SOS-DEF-540/SOS-BUG-665. If you have any questions about our bug fixing process, I recommend reading this article in our community.Jamie
It's been internally noted that the cause of the bug is technical debt around the CKEditor control and that this may be fixed with the CKEditor upgrade we're planning on doing. Unfortunately I don't have a specific date as to when this will be implemented but it is currently on our Product teams roadmap for one of our next few releases. We also know that this update will fix at least a few of our CKEditor related bugs.
