Thanks Manel! Definitely keep an eye on that idea card for updates; I'll be closing this thread due to its age.
Carly Rossi // she/her
Portland, OR
Sent: 03-30-2023 01:07
Subject: Create Test Plan/ Test Runs from JAMA test case baseline
Hi Carly,
I added there a couple of impacts we are facing if we re-use the Test Cases. I Hope this could be solved in a different way in the future.
Manel Moreno
SW Test Manager
Systelab Technologies
Sent: 03-28-2023 14:55
Hi Manel,
The workaround would be to re-use them, but there isn't currently a way to resolve the traceability bit. That said, I'd recommend voting on the idea card Gulam submitted (if you haven't already), as well as sharing your usage case and how traceability comes into play, to add additional context for our Product team.
Portland, OR
Sent: 03-14-2023 05:12
We have Exactly the same need: we need to execute the Test Cases as they were on the release date (baselined).
Is the only solution to clone (re-use) them? How to solve then the problem with the traceability to the released requirements (also in the same baseline)?
Manel Moreno
SW Test Manager
Sent: 03-28-2022 09:23
For the record, we ran into the exact same scenario today. We have a released test plan, but have been making updates in the meantime. We want to execute on the released plan, but cannot create our test cycle from the baseline for the release.
Gulam Emadi
Sent: 04-16-2021 16:04
Hi Bartek,
Thanks for reaching out! There is no way to create a Test Plan/Cycle on a Baseline.
You could visit our Ideation module and submit this as an idea. This is a valuable space where we solicit and gather product feedback. You can go here, and use the search functionality to see if your idea is already in there. If it is, then you can vote and comment on the card. If there isn't, please post a new idea card.
Let us know if you have any questions.
Sent: 04-14-2021 23:49
Sometime ago I created baseline for my test cases in JAMA. After the baseline was created, we started updating the test cases for new version of the product. However, I still have to execute tests from baseline for previous version of the product. Is it any solution to create test plan based on the baseline which i created ( in the test plan/test cycle I would like to have test run corresponding with version of the test cases from baseline).
Any GUI option or REST API to support creating test run based on the specific version of the test case?
Thanks in advance
Bartek
Bartek LastName
S3 Group
