Dear both,
we are experiencing the same problem and addressed it to the Jama Hotline some time ago. We were trying to detect Test Cases that were not scheduled/run/.... They answered that it does not work because not every test case has a test run... (And those that don't have a test run, cause the error, because there is nothing to check)
So it seems to be intrinsic.
If you find a work around, please post it here.
Thanks and Greeting,
Cornelia Retsch
Saint-Gobain
Sent: 11-25-2022 07:00
Subject: Embedded filter - 2 level filtering
Hi HA EL,
just access the console and generate a Support bundle. I assume it is in the logs of JamaCore.
As I see in the screenshot there is an issue in the embedded filter.
I expect something like
Anyway, I got the same error if setting it in an embedded filter -> going to check ... let you know ...
com.jamasoftware.contour.api.exception.ScopeRefObjectNullException: Item with ID does not exist
I think it is something for Jama Support ...
Best regards,
Sent: 11-25-2022 03:16
Use case: Filter Requirements that are linked to test case that are in Test runs based on thei status (Failed/Passed/Blocked)
When selecting Has Test Run Results field in the Embedded filter, JAMA throws an error
How to access the server logs for troubleshooting this bug?
