  • 1.  Export of Categories does not work
    Posted 01-22-2024 05:17
    I would like to export Items from Jama (with customized Office Template) which are assigned to different categories. Regarding this I want to export these Items with their categorie.
    I used the field «categoryPaths» as it is described in the Reference Guide but it does not work?!
    Is there another solution?
    Best regards,
    Verena Neumaier
    Verena Neumaier
    Aktormed GmbH
  • 2.  RE: Export of Categories does not work
    Posted 01-22-2024 23:14
    unfortunately this does not work and it is a known defect: Export of Categories does not work | Support (jamasoftware.com).
    As an alternative, you can use a velocity report to export the categories: Category Name in Velocity Report instead of Path? | Support (jamasoftware.com)
    Here are some tips for creating a velocity report:  Quick Start: HTML Templates for Velocity PDF Reports (jamasoftware.com).
    Best regards, Iwan
    Iwan Kutter
    Requirement Engineer
    Bernina International
  • 3.  RE: Export of Categories does not work
    Posted 01-23-2024 00:38
    BTW, is Jama Software planning to fix the defect???
