  • 1.  Filter based upon location/function of related requirements
    Posted 10-06-2023 05:09
    For reviews we'd like to create filtered sets of requirements based upon what they are related to.
    For example, lets say we have functions: A, B & C. I am in function A but some of my requirements are related to requirements in function B & some relate to requirements in function C.   I'd like to get the set of my "A" requirements that relate to "B" so that I can get someone from team B to review that subset only.
    What is the easiest way of doing this?
    I can't define location in a sub-filter - I see that is a long term roadmap item.
    We have the functional discipline captured in the project ID, eg thisProj_A_SLR_, thisProj_B_SLR_ etc, but I don't seem to be able to parse that in a filter either
    Maybe I have to add tags - but seems a shame if links already exist.
    Any help appreciated
    Fraser Macmillen
    Vertical Aerospace
    Bristol
  • 2.  RE: Filter based upon location/function of related requirements
    Posted 10-09-2023 08:54
    We do a similar thing with items in Project A that link upstream or downstream to items in Project B.  We can filter for items in Project A that have a downstream link (for instance) to items in Project B with a subfilter that looks for the Project ID string of items in Project B...
    Alex
    Fujifilm Sonosite
  • 3.  RE: Filter based upon location/function of related requirements
    Posted 10-10-2023 01:36
    Edited by Fraser Macmillen 10-10-2023 05:51
     [removed - superceded]
  • 4.  RE: Filter based upon location/function of related requirements
    Posted 10-10-2023 01:43
    Hello Fraser,
    just an idea - you can tag all function B related requirements using batch edit in two clicks and then use Tags in subfilter.
    Maybe not the cleanest solution, but should work.
    Roman Sickaruk
    ON Semiconductor
  • 5.  RE: Filter based upon location/function of related requirements
    Posted 10-10-2023 05:50
    Found the answer - do the above but also use wild-cards, i.e. *B_SLR* will find all instances of that string within a longer string
    Fraser Macmillen
    Vertical Aerospace
    Bristol
