Hi all,
I am trying to do a relationship import with about 100 relationships in my spreadsheet. Whenever I try to use the import plugin I created, the importing screen infinitely keeps going, or sometimes stops with no success/error message (and no relationships created). I also did an almost identical import right before this one with the same plugin, item types, and import file format. A bit stumped on what changed between the two files, any help is appreciated.
Edit: I am also not able to manually create relationships with the items I want.
D
Dhyan Patel
