Product
  • 1.  Solution to only allow Approved Test Cases be added to a test plan
    Posted 13 days ago
    We have a need to restrict the test cases that are able to be added to a test plan to only those that are Approved/ Accepted. I have seen older posts asking for the same thing. Is there any update on being able to achieve this? Or a workaround that is able to be applied?
    Christina
    Christina Muller
    Mammoth Biosciences
    Brisbane CA
  • 2.  RE: Solution to only allow Approved Test Cases be added to a test plan
    Posted 9 days ago
    We would also appreciate this feature, we are currently checking this manually and of course that always has the risk of something slipping through which is against our documented processes
    Andrew MacCormack
    LumiraDX
  • 3.  RE: Solution to only allow Approved Test Cases be added to a test plan
    Posted 3 days ago
    I'd suggest using an Advanced Filter to populate your Test Plan with Test Cases.
    Geoffrey Clemm
