  • 1.  SOS-DEF-5056 relating items to components
    Posted 17 days ago
    Question for other users: Anyone else has used relationships from items to Components regularly?
    I am aware that this was a defect (SOS-DEF-5056) , and I checked with support last summer and they did not have it on the roadmap for a fix any time soon. It's not on any release notes either, or user guides.
    We just upgraded our Dev server from 8.79.1 to 9.6.3 (self hosted), and now we can't create these relationships to components, it actually shows a popup stating it's not allowed. Anyone else that was using relationships to components? Which alternate option worked best for you? We are evaluating traces to other items, tags, or categories, but no option is as optimal as the traces to components.
    Lita Gribben
    Blue Origin
  • 2.  RE: SOS-DEF-5056 relating items to components
    Posted 17 days ago
    Hi Lita,
    I have just tested this with 9.6.3 on-prem: I still can set relationships (between components via add -> related item).
    Now about your question ...
    I think it was me stressing on this issue/feature -> Relationships for Components
    • My first issue is congruency: either all containers (components, sets, folders) or none. In my case I have mostly folders: in order to somehow use SOS-DEF-5056 as "feature" I need to have it also for folders.
    • Another issue is more related to the possible semantic related to such relationships. Example 1: item to component/component to item -> does it means the relationship applies to the items contained in the component? What about moving items from/to the component ... that's to "weak" for me (better to explicitly setting the relationships between item and contained items. Example 2: component to component -> it is the case if performing a reuse with a component and setting "add a relationship from the original item". Undesired but can be tolerated. As previously said, either all container types or none.
    I try to avoid such relationships: my general strategy here is "less is more, more is specific" -> in other words: do not exaggerate with relationships. If used, then with "strong" semantic.
    I hope it helps
  • 3.  RE: SOS-DEF-5056 relating items to components
    Posted 16 days ago
    Alessandro, thanks for the details! I realized my post should have been more specific. Since you mentioned the relationship works for you, I re-read your post and I believe the way you created the relationship was from Component to single item, and what stopped working for us is the other way, from an item (or items) to add the relationship TO a component, that's where we get the error "Invalid:
    Components cannot have relationships". I just tested going into the Component to add the relationship from Component TO item, and sure enough that does work. Also, the Relationship rule configuration still allows us to configure relationships to Components.
    We don't use this to replace individual traces, but as a placeholder prior to the decomposition, then we can compare that all our preliminary allocations (relationships to components) match the decompositions that are held inside of that component. So a sort of placeholder/guide.
    Lita Gribben
    Blue Origin
  • 4.  RE: SOS-DEF-5056 relating items to components
    Posted 16 days ago
    Edited by Alessandro Valli 16 days ago
    HI Lita,
    you are right: just tested in 9.6.3 and 9.79.7 on-prem.
    In 9.6.3 you cannot set upstream/downstream relationships from an item (not a container) to a component via relationships widget.
    The REST API still works (POST /relationship).
    My previous test was in creating a related item and it worked both ways (item -> CMP; CMP -> item)
    Best regards,
  • 5.  RE: SOS-DEF-5056 relating items to components
    Posted 16 days ago
    Hi Lita,
    We also do not use the relationship to components because of this defect. But for your information, I created an idea some time ago to officially have a relationship to folders: Idea Details - Jama Software Community
    Note: On Version 9.7.0 cloud, we can still add a relationship to a component
    Iwan Kutter
    Requirement Engineer
    Bernina International
  • 6.  RE: SOS-DEF-5056 relating items to components
    Posted 16 days ago
    Hi Lita,
    If Components are not included in your project relationship rules, check to see if the relationship rule set allows for any item type not mentioned in this rule set to be related to any item type including those in the rule set.
    Testing in one of my sandboxes, when Components are not included in the relationship rule set and that option is not enabled, I am unable to relate components to other items.
    Patrick Garman
  • 7.  RE: SOS-DEF-5056 relating items to components
    Posted 16 days ago
    Patrick, I tested both ways on our upgraded version (9.6.3). Since we have been using relationships to components (from items), and now instead of adding the relationship (as it did in 8.79.1), it shows an error telling the user "Components cannot have relationships". The components were indeed in the rule set for my testing, and I checked the box to allow any relationship as well as part of my testing.
    Generally, if an item type is not added to the rule set, the system will either grey out or not show that type as an option. With components being part of the rule set, they are not greyed out, and the message shown is brand new to this version.
    From the comments above I was able to confirm I can use "Add related" from the item to create a component, but that doesn't match our use case. I can also add the relationship from the Component to an item as per the rule set. But the opposite from the item to the component prompts the error.
    This to me seems like either a half fix, or accidental fix. I contacted our TAM about this and he's researching what happened since this was not marked for fixing.
    Lita Gribben
    Blue Origin
  • 8.  RE: SOS-DEF-5056 relating items to components
    Posted 2 days ago
    As a housekeeping note, because Product discussions are being archived, this thread has been moved to Support discussions.
    Carly Rossi // she/her/hers
    Portland, OR
