So we just had an interesting thing happen, and im pretty sure this is a bug.
User 1 has an object open on their computer.
User 2 edits the same object on their computer making a user lock.
User 1 does not refresh their browser, and transitions the lifecycle/workflow to a state that creates a system lock
Jama does not give an error. It creates the system lock, performs the transition, but does not refresh the screen.
After a refresh, the lifecycle/workflow transition is now grayed out, even though User 2 and Org Admin have a valid transition available because user 1 has the object locked still.
This fact is not visible to admins/anyone but User 1.
I had to as org admin, go clear the system lock manually, which revealed the user lock "underneath" which I then removed. (User 1 was gone for the day)
Its weird to me that a user locked item can be transition out from under their change.
FYI, we are running self hosted
Jama Connect 8.66.1
If it matters, (I havent tested, but I don't know why it would) I am running firefox.
I also tested that if I have two tabs open, and I edit on one, and transition on the other, it works fine. It has to be 2 different users.
RAD------------------------------
Rory Duncan
NASA
Kennedy Space Center FL
