  • 1.  Tag Cloud to be collapsed by default
    Posted 09-06-2022 09:02
    I have a user that wants to set the Tag Cloud to be collapsed by default.  I saw the below post, however it was written in 2017, and I can't find the settings mentioned there.  I there still a way to update the setting?
    https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?MessageKey=97c9365f-40ba-425b-8664-2dc293575425&CommunityKey=c9d20d4c-5bb6-4f19-92eb-e7cee0942d51&tab=digestviewer
    Martha Fiske
    Lucid Motors
  • 2.  RE: Tag Cloud to be collapsed by default
    Posted 09-06-2022 22:00
    The mechanism is the same, but the icon has changed.   In particular, in current versions of Jama, to the right of the project name, you will see an icon that is a rectangle divided into 3 sub-rectangles.   If you hover over that icon, the hover tip will say "Change layout".  Click on that, and you will get the dialog box described in the 2017 post.
    Geoffrey Clemm
  • 3.  RE: Tag Cloud to be collapsed by default
    Posted 09-07-2022 07:51
    Thank you Geoffrey!
    Martha Fiske
    Lucid Motors
