When we test HW We use one test case in one test cycle with multiple samples.
In the description we might indicate sample size as 10. In our steps, we would then have a step saying "Repeat previous steps according to sample size". The result column will then contain results from all samples. You could also have one step per sample, if it is known beforehand.
If we have a test fail, we will then create a new cycle containing that test case. It might not be the best in your case if multiple people will enter information, but it is still possible, they just can't do it at the same time.
Jacob Brodal
3Shape
Sent: 01-22-2023 21:55
Subject: Test Cycles with multiple samples
I think that's my best option here. For my specific situation though, every cycle will always require multiple samples. So if I have one failure, I'm going to test a new set of samples. Ideally, they're organized within a cycle.
Jomar Ochoco
MN
Sent: 01-22-2023 18:52
You can create additional cycles (one for each sample). In the Description field of the cycle, indicate what sample is being tested.
Geoffrey Clemm
Sent: 01-18-2023 13:44
Hello. I'm using Jama to track my hardware testing.
For each test cycle, I need to test multiple samples of my hardware. Is there a way I can further separate a cycle into each sample so that different people can test their hardware sample and enter in their data independently?
Jomar Ochoco
MN
