  • 1.  Timestamp associated with execution of the Test Step within a Test Run
    Posted 03-07-2023 11:47
    Edited by Vishal Shanbhag 03-07-2023 11:49
    Context: We have a set of test cases which have multiple test steps. Each of those individual test steps needs to be marked as a Pass/Fail when we execute the test run.
    Why we need to have a timestamp with each step execution in a test run: In the AV industry, while executing vehicle tests, we need to know the exact moment at which a step was executed in order to be able to trace back to that data for purpose of presenting a proof or for debugging.
    What currently exists:  The  test run has a date and a timestamp associated with it.
    Question: Does the step within a test run execution have an associated Date and Timestamp? If yes and not shown through the browser window, how can I access the date and timestamp associated with a Step within the Test Run.
    Vishal Shanbhag
  • 2.  RE: Timestamp associated with execution of the Test Step within a Test Run
    Posted 03-22-2023 19:43
    Hi Vishal, can you check out the activity and version widgets within the test run items and tell us if this has the appropriate level of detail for what you are looking for? The activity and version widgets must be enabled on the test run item by an Admin in order to see them on the item type. Each of these widgets have a different type of change log information.
    Ashley Ernst
    CA
  • 3.  RE: Timestamp associated with execution of the Test Step within a Test Run
    Posted 03-22-2023 22:32
    Hello Ashley,
    Thank you for the response. I have admin rights and the activity widget is enabled for the Test Run item type as shown below in the screenshot.
    I am able to see the changes to the test run attributes as shown below in the screnshoot
    Below is how the test run is defined (Test Run has multiple steps which are to be marked as a pass/fail individually when a test run is executed)
    As you can see above, the test step 1 within the test run does not have a change log or a time at which it the status of the step 1 was changed from Not Run to Passed. How can I access the timestamp at which the test step status was changed?
    Vishal Shanbhag
  • 4.  RE: Timestamp associated with execution of the Test Step within a Test Run
    Posted 04-04-2023 12:36
    Vishal, after further investigation, there is no place in the database that currently tracks changes per test step with a timestamp. As you've noticed, the system currently aggregates all changes to an item's version into one activity log only when the user hits 'save and close'. As of today, our product roadmap does not include plans to introduce timestamps at the individual step level.
    I did a quick search through our current user 'Product Ideas' in the Community's Product space and didn't find any existing ideas that resemble your usage scenario. You may add a new Idea so other users with similar process/usage needs may like and comment.  Our Product team regularly reviews these ideas to track which ideas gain traction across our user base.
    To add an Idea, navigate to the top of this page and click the 'Product' dropdown then select 'Ideation' from the available options. This will take you to the Product Ideation area of the Community site where you click 'Add' to create a new Idea where you can describe your process and usage scenario for the Product team and other users to review.
    Ashley Ernst
    CA
