  • 1.  Velocity Excel report that has more than one sheet
    Posted 09-29-2023 05:28
    It it possible to write a custom Velocity report that exports to an excel containing multiple sheets ?
    Uwe Matzen
    Otometrics (Natus Medical Denmark)
  • 2.  RE: Velocity Excel report that has more than one sheet
    Posted 10-02-2023 07:25
    Yes, this is possible. You can start with creating the file with the sheets you need in excel, then save it as Single File Web page (file ending .mht) and then rename the file ending to *.vm.
    Inside the file, the sections are separated with "------=_NextPart_...." and each sheet should be annotated with sheet001.htm, sheet002.htm, etc.
    Then add your velocity code to the respective sheet.
    Patrick
  • 3.  RE: Velocity Excel report that has more than one sheet
    Posted 10-02-2023 07:32
    Do you know if it's possible to have the velocity report separate items based on folders into separate excel tabs? For example, I have a Set with 4 folders filled with items and I want each folder put into separate excel tabs. I would think it's similar to how velocity can do hierarchy based on folder level and turn them into headings for Word but I'm not sure how to apply that to Excel velocity exports.
    Sara Wertanen
    Oceaneering Entertainment Systems
    FL
  • 4.  RE: Velocity Excel report that has more than one sheet
    Posted 10-03-2023 02:52
    This is probably not so straight forward, but you could maybe write a macro which creates a sheet for each folder. Difficulty is probably to let the code create the file list and the array of Tab names, which have to come at the beginning of the file.
    Patrick
