How to import a visio diagram
Harald Hotz-Behofsits
Member Posts: 159
The diagram tool from jama connect is actually capable of doing that, but is not accessible.
you can import visio at Flowchart Maker & Online Diagram Software
here create a new diagram, store it on your device
then use in the file menu the import function and import the visio diagram
then mark all with CTRL-A
now switch to jama and edit the requirement that should have the visio inside
insert a diagram by clicking on add/edit diagram
in the popup do "edit file" in the file menu
you see some xml content, replace that with the content of the clipboard
then close with ok
then click save and close
done
an alternative location for doing the conversion could be confluence with the draw.io plugin, the steps are quite similar.
regards
Harald
then close with ok
done
regards
Harald
